On 2012-04-17 Bai Jiaoni wrote:
> I can not use A32 address 0x20600000 to access hardware register
> immediately After I download vxworks from server to mvme5100. But at this
> moment if I execute the special function whose work is as following, I can
> use 0x20600000 to access the hardware register. Can you give me some idear
> from the information provided about what this function do to help register
> access successfully?
That routine must be configuring one of the PCI Target Image windows in the
Universe-2 chip, although it doesn't show that in the output you posted. It
does claim to be configuring one of the VMEbus Slave Image window registers
VSI1_CTL but that is used for VMEbus cycles initiated by a different bus
master to give it access to the RAM on your MVME5100 board.
You are probably going to have to understand how your Universe-2 chip is
configured and to make changes to the settings that your mv5100 BSP uses; to
do that, you need to learn about the Universe-2 configuration registers. You
can download the User Manual for the Universe-2 chip from Tundra.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- hardware register access Bai Jiaoni
RE: Channel Access problem over SSH Hill, Jeffrey O
Re: Channel Access problem over SSH Andrew Johnson
<2012>
2025
2026
Java/Eclipse/CSS Expertise and Python/PyQt/RDB/IRMIS Expertise Needed - to hire or collaborate Dalesio, Leo
<2012>
2025
2026
