Subject: Re: mrfioc2 compile error
To: 송영기 <[email protected]>
Cc: [email protected]
Date: Fri, 20 Apr 2012 15:48:34 +0100
On Fri, 2012-04-20 at 21:30 +0900, 송영기 wrote:
> Hi All,
> I am trying to compile the mrfioc2 drivers using the tutorial (Getting
> started with EPICS on RTEMS).
> The target board for the mrfioc2 is mvme3100.
> The tool source files and packages are as follows:
> binutils-2.19
> gcc-g++-4.3.2
> gcc-core-4.3.2  / gcc-core-4.3.2-rtems4.9-20081214.diff
> newlib-1.16.0 / newlib-1.16.0-rtems4.9-20090324.diff
> rtems-addon-packages-4.9.2
> rtems_libbspExt_1.5
> I successfully compiled gcc to cross-compile for powerpc-mvme3100 and
> created an example application with base-3.14.12.1.
> For compiling the mrfioc2, i added the location of external products
> including epics_base, devlib2 and autosave in
> mrfioc2/configure/RELEASE.
> When i tried to compile the mrfioc2, i get the error message as
> follows:
I had the same problem, and I think was the version of g++. I was using
4.1.2.
In devObjWf.cpp I replaced <epicsInt32[]> with <epicsInt32 *>,
<epicsInt8[]> with <epicsInt8 *> etc, and then it built correctly.
Paul.
RE: mrfioc2 compile error Davidsaver, Michael
mrfioc2 compile error 송영기
Prev: Re: mrfioc2 compile error Michael Davidsaver
Next: RE: mrfioc2 compile error Davidsaver, Michael
