Hello Young-gi,
Can I ask you to try again with the development version? Run
hg clone http://epics.hg.sourceforge.net:8000/hgroot/epics/mrfioc2
Michael Davidsaver
On 04/20/12 08:30, 송영기 wrote:
> Hi All,
> I am trying to compile the mrfioc2 drivers using the tutorial (Getting
> started with EPICS on RTEMS).
> The target board for the mrfioc2 is mvme3100.
> The tool source files and packages are as follows:
> binutils-2.19
> gcc-g++-4.3.2
> gcc-core-4.3.2 / gcc-core-4.3.2-rtems4.9-20081214.diff
> newlib-1.16.0 / newlib-1.16.0-rtems4.9-20090324.diff
> rtems-addon-packages-4.9.2
> rtems_libbspExt_1.5
> I successfully compiled gcc to cross-compile for powerpc-mvme3100 and
> created an example application with base-3.14.12.1.
> For compiling the mrfioc2, i added the location of external products
> including epics_base, devlib2 and autosave in mrfioc2/configure/RELEASE.
> When i tried to compile the mrfioc2, i get the error message as follows:
> make -C ./configure install
> make[1]: Entering directory
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/configure'
> perl
> /usr/local/epics/base_ppc/rtems/base-3.14.12.1/bin/linux-x86/makeMakefile.pl
> O.linux-x86 ../..
> perl
> O.RTEMS-mvme3100 ../..
> mkdir O.Common
> make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
> make[2]: Entering directory
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/configure/O.linux-x86'
> perl
> /usr/local/epics/base_ppc/rtems/base-3.14.12.1/bin/linux-x86/convertRelease.pl
> checkRelease
> make[2]: Leaving directory
> make -C O.RTEMS-mvme3100 -f ../Makefile TOP=../.. T_A=RTEMS-mvme3100 install
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/configure/O.RTEMS-mvme3100'
> perl
> checkRelease
> make[1]: Leaving directory
> make -C ./mrfCommon install
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/mrfCommon'
> make -C ./src install
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/mrfCommon/src'
> perl
> O.linux-x86 ../../..
> perl
> O.RTEMS-mvme3100 ../../..
> mkdir O.Common
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[3]: Entering directory
> `/usr/local/epics/base_ppc/rtems/Event/mrfioc2-2.0.0/mrfCommon/src/O.linux-x86'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -DDEBUG_PRINT -D_X86_ -DUNIX
> -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -DDEBUG_PRINT
> -m32 -g -fPIC -MMD -I. -I../O.Common -I. -I../os/default -I..
> -I../../../include/os/Linux -I../../../include
> -I/usr/local/epics/base_ppc/rtems/base-3.14.12.1/include/os/Linux
> ../mrfFracSynth.c
> ../linkoptions.c
> /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC
> ../cardmap.cpp
> ../object.cpp
> ../devObjAnalog.cpp
> ../devObjLong.cpp
> ../devObjBinary.cpp
> ../devObjMBB.cpp
> ../devObjMBBDirect.cpp
> ../devObjWf.cpp
> ../mrf/object.h: In member function `std::auto_ptr<mrf::property<P> >
> mrf::Object::getProperty(const char*) [with P = epicsInt8[]]':
> ../devObj.h:155: instantiated from `long int
> add_record_property(dbCommon*, DBLINK*) [with P = epicsInt8[]]'
> ../devObjWf.cpp:26: instantiated from here
> ../mrf/object.h:277: error: invalid use of array with unspecified bounds
> mrf::Object::getProperty(const char*) [with P = epicsUInt8[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = epicsUInt8[]]'
> ../devObjWf.cpp:28: instantiated from here
> mrf::Object::getProperty(const char*) [with P = epicsInt16[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = epicsInt16[]]'
> ../devObjWf.cpp:30: instantiated from here
> mrf::Object::getProperty(const char*) [with P = epicsUInt16[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = epicsUInt16[]]'
> ../devObjWf.cpp:32: instantiated from here
> mrf::Object::getProperty(const char*) [with P = epicsInt32[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = epicsInt32[]]'
> ../devObjWf.cpp:34: instantiated from here
> mrf::Object::getProperty(const char*) [with P = epicsUInt32[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = epicsUInt32[]]'
> ../devObjWf.cpp:36: instantiated from here
> mrf::Object::getProperty(const char*) [with P = float[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = float[]]'
> ../devObjWf.cpp:38: instantiated from here
> mrf::Object::getProperty(const char*) [with P = double[]]':
> add_record_property(dbCommon*, DBLINK*) [with P = double[]]'
> ../devObjWf.cpp:40: instantiated from here
> make[3]: *** [devObjWf.o] Error 1
> make[3]: Leaving directory
> make[2]: *** [install.linux-x86] Error 2
> make[1]: *** [src.install] Error 2
> make: *** [mrfCommon.install] Error 2
> Could you tell me how to do?
> Thanks in advance,
> -Young-gi
- mrfioc2 compile error 송영기
RE: How to apply for Java SWT DateTime widget in CSS OPI? [SEC=UNCLASSIFIED] Chen, Xihui
Re: mrfioc2 compile error Paul Hamadyk
<2012>
2025
2026
<2012>
2025
2026
