Hi Mark,
In BOY, you can use Rule without using script to hook up a PV value with a widget property.
I'm sorry that I cannot find your last message describing the waveform format convention for areaDetector. For example, for a 2*2 RGB image, is the waveform something like [p11, p12,p21,p22] and each pixel=R+G<<8+B<<16?
Xihui
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, May 01, 2012 10:45 AM
> To: Chen, Xihui; Pavel Masloff
> Cc: EPICS Tech Talk
> Subject: RE: [Scopes] BMP image record??
> ➢ Hi Mark, if you can give me the standard waveform format for true
> color image, I can make the BOY intensity graph widget support it.
> It’s in my last message on tech-talk. It is a naming convention for
> areaDetector, which you probably don’t want to hard-code into BOY. But
> you should provide an easy way for the BOY intensity widget to get the
> image dimensions from other PVs, without having to write a script.
> That is what EDM does. And then you could assume that if the first
> dimension is 3, and the third dimension is non-zero, that it is an RGB1
> image, which is the most common type of RGB image (pixel interleave).
> Mark
> From: Chen, Xihui [mailto:[email protected]]
> Sent: Tuesday, May 01, 2012 9:41 AM
> To: Pavel Masloff; Mark Rivers
> Cc: EPICS Tech Talk
> It can be an ordinary EPICS waveform.
> Hi Mark, if you can give me the standard waveform format for true color
> Thanks,
> Xihui
> From: Pavel Masloff [mailto:[email protected]]
> Sent: Tuesday, May 01, 2012 9:44 AM
> To: Mark Rivers
> Cc: EPICS Tech Talk
> Subject: Re: [Scopes] BMP image record??
> Should the Waveform PV be of areaDetector type? Or it can be an
> ordinary EPICS wafeform
> On Tue, May 1, 2012 at 4:12 PM, Mark Rivers <[email protected]>
> wrote:
> The intensity widget only supports monochrome, with color lookup tables
> within BOY. It does not support true color, i.e. RGB images or images
> with their own color maps.
> Hopefully it will be added in the future, because we would like to use
> BOY with color cameras.
> There is an ImageJ plugin in the EPICS areaDetector package that does
> support both true color and monochrome images in waveform records.
> Mark
> ________________________________
> From: [email protected] [[email protected]] on
> behalf of Pavel Masloff [[email protected]]
> Sent: Tuesday, May 01, 2012 1:57 AM
> To: Matt Newville
> Cc: EPICS Tech Talk
> Alright!
> Cancel my last message!
> I should have used gif files when I tried bmps. SO the intensity widget
> supports monochrome images. And what about colorful images?
> On Tue, May 1, 2012 at 10:30 AM, Pavel Masloff
> <[email protected]<mailto:[email protected]>> wrote:
> Matt that's an exhaustive explanation! Thanks.
> Still I can't get a decent picture in BOY :((
> On Tue, May 1, 2012 at 5:15 AM, Matt Newville
> Hi Pavel,
> On Mon, Apr 30, 2012 at 3:20 PM, Pavel Masloff
> > Hey Matt,
> > Thanks for sharing! I can't make your code work, though. Every time I
> get
> > some gibberish image, You might have forgotten to convert int to
> string?
> > I am using the following script.
> > Image file -> waveform:
> > import Image
> > import StringIO
> > from epics import PV
> > f = open('hello.bmp') # source image file
> > data = f.read()
> > chan = PV ('file')
> > chan.put(data)
> Sorry, I think I may have misunderstood your intent. Your script
> takes the contents of the file and puts it into a waveform PV. That's
> a fine thing to do, but it is not putting the image data to the
> waveform PV. It's an interesting approach... one could do the same
> with any file, as long as the consumer of the PV knows what format the
> file is meant to be.
> > Waveform -> image file:
> > import os, sys
> > import Image
> > import StringIO
> > chan = PV ('file') #waveform pv
> > data = chan.get() #waveform.val
> > sdata = ''.join(chr(x) for x in data)
> > sfile = StringIO.StringIO(sdata)
> > im = Image.open(sfile)
> > im.save("yoyo.bmp")
> > im.show()
> Right - That should work, reading the waveform data as the file
> contents, and interpreting it as an image file (not the data of an
> image).
> > Another thing I can't understand - the Intensity widget in BOY. I
> don't know
> > how to set its properties. I set PV name, Data height, Data width,
> Max, Min.
> > And get an ugly image.
> Probably because your waveform record holds the bytes of the image
> file, not the image data.
> > Could you also explain to me how the trasformation image binary file
> > waveform and back happens? As I understand an image is roughly a set
> of
> > pixels each with its own color. There is also a header (which we
> don't
> > need?) Then we read the file and forward every byte into the waveform
> record
> > which is of type unsigned char (integers 0-255) with a size = 1byte.
> So in
> > order to get an image out of the waveform we should break the
> waveform N
> > times with an interval M (if our image dimensions are N*M). There is
> also a
> > Color map which specifies what color our integers equal to.
> > Now when we want to convert our waveform back to file we are using
> the
> > chr(x) function, I don't know why.
> Your method is definitely sending the BMP header information. That
> should be OK, but it means the consumers have to know they're getting
> a BMP file, not image data. I think that might be the issue. You
> could try something like this (untested!) to have the waveform hold
> the image data:
> :: Image file -> waveform:
> import Image
> import numpy as np
> chan = PV ('file')
> im = Image.open('hello.bmp')
> chan.put(im.getdata())
> # or, if that complains, perhaps
> # chan.put(np.array(im.getdata(), dtype='uint8').flatten())
> That will post the image data to the waveform, and should work with
> any image file, though you might have to play with the conversion
> depending on what's in the image file. The advantage is that any CA
> client (say, BOY or Python) should be able to read the waveform as
> image data and know what to do with it. You might want to add a
> couple auxiliary PVs where you can put the image size NX, and NY and
> format (8-bit greyscale, RGBA, etc) from your Image file-> waveform
> publishing script. This is what AreaDetector does, and it allows
> clients to look up the sizes and formatting without guessing.
> A consumer script then might then look more like I suggested earlier:
> :: Waveform -> image file:
> import Image
> chan = PV ('file')
> data = chan.get()
> im = Image.frombuffer('L', (nx, ny), data, 'raw', 'L', 0, 1)
> im.show()
> im.save("yoyo.bmp") # or 'yoyo.png', .jpg, etc
> Again, you might need to carefully check the details of your bitmap
> file, as bitmaps can vary, with palettes, etc.., and other formats can
> have other sorts of issues. If you assume it's 8-bit greyscale (as
> 'L' here does) and you get wonky looking images, you might need to
> adjust that, or better yet, adjust the image you post so that the
> posted data can be consumed easily as an 8-bit greyscale or RGB color
> image, or whatever is appropriate.
> > Next thing as you mentioned is the NELM field and
> EPICS_CA_MAX_ARRAY_BYTE
> > variable. So if our image is say 400*300 24 bit BMP image, does it
> mean we
> > should set NELM=400*300 and EPICS_CA_MAX_ARRAY_BYTE=400*300*24?
> EPICS_CA_MAX_ARRAY_BYTES (With 'S') should exceed 400*300*3. If you
> make your 'file' PV larger than you actually need, the put() will fill
> in the first part of the waveform and leave the rest untouched. You
> can count down on network traffic by asking for the appropriate size
> instead of the full waveform. Whether that matters depends, of
> course.
> Hope that helps,
> --Matt
> Best regards,
> Pavel Maslov, MS
> Controls Engineer at Pulsed power Lab
> Efremov Institute for Electro-Physical Apparatus
> St. Petersburg, Russia
> Mobile: +7 (951) 672 22 19
> Landline: +7 (812) 461 01 01
> Best regards,
> Pavel Maslov, MS
> Best regards,
> Pavel Maslov, MS
- [Scopes] BMP image record?? Pavel Masloff
- RE: [Scopes] BMP image record?? Mark Rivers
- Re: [Scopes] BMP image record?? Pavel Masloff
- RE: [Scopes] BMP image record?? Wang Xiaoqiang
- Re: [Scopes] BMP image record?? Matt Newville
- RE: [Scopes] BMP image record?? Chen, Xihui
Re: ECHO variable in build rules Andrew Johnson
Re: does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
<2012>
2025
2026
<2012>
2025
2026
