Subject: Re: [Scopes] BMP image record??
To: Rod Nussbaumer <[email protected]>
Date: Fri, 4 May 2012 10:15:19 +0400
Hi Rod,
We have 2500 points per waveform. Our PCs are equipped with COM ports only, no GPIB cards. One waveform is 73,5 KB to be exact. The RS232 connection speed is maximum 19200 Kb/s at maximum. For the time being I just want to check whether the experiment went fine, no false triggering, etc. In the future, I would like to analyze the waveforms in matlab via CA. So this will be handy.
What is the speed of the GPIB interface on Tek scopes, anyway?
On Fri, May 4, 2012 at 1:42 AM, Rod Nussbaumer <[email protected]> wrote:
Pavel:
Every Tektronix scope I've set up communications with had a 500 point waveform (as well as some substantially larger ones). Presently, I'm acquiring those at 10 waveforms per second (over GPIB). Are you sure that would not suffice for you? Is GPIB an option? Much much faster.
  ---   rod.
Pavel Masloff wrote:
Mark,
A waveform weighs 70kB. 4 waveforms = 280 kB. 280 vs 40. I would have to
wait a couple of minutes till the data is processed. 10-15 seconds for
the screen dmp.
On Thu, May 3, 2012 at 11:13 PM, Mark Rivers <[email protected]
<mailto:[email protected].edu>> wrote:
   It may be time to back up a step.  Why not transfer the waveforms
   themselves, rather than a screen dump?  There are others in the
   EPICS community who have already done that for the scopes you are using.
   __ __
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [Scopes] BMP image record?? Rod Nussbaumer
[Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Dirk Zimoch
Re: [Scopes] BMP image record?? Pavel Masloff
RE: [Scopes] BMP image record?? Mark Rivers
Prev: Re: [Scopes] BMP image record?? Rod Nussbaumer
Next: ioc with genSub record: compiling error Maurizio Montis
Next: Re: [Scopes] BMP image record?? Rod Nussbaumer
