1) Did you do a 'make distclean' from your application top directory first?
Now two unsolicited suggestions:
1) Is your application invoking this subroutine for anything other than startup/initialization? If you plan to invoke this subroutine during regular IOC operation I think that you are using record processing improperly. "Slow" I/O operations should not be performed in the context of record processing. You should use the ASYN support module instead -- this will allow your application to perform the I/O in a separate thread and not interfere with processing of other records.
2) The aSub record is now distributed as part of base. This record is more capable than genSub and requires no extra support modules to be added to your application.
On May 4, 2012, at 1:36 AM, Maurizio Montis wrote:
> Hi all,
> i'm trying to create an ioc application having genSub record available
> for reading data from particular files. I wrote a basic C file and the
> dbd file (to register function implemented) for this task, modified the
> Makefile in the "src" subdirectory and configure/RELEASE for the genSub
> record support, but i'm not able to complite it.
> The error is:
> make[4]: *** No rule to make target
> '../../../../lib/linux-x86/libgensub.a', needed by 'ioc1wire'. Stop.
> I found a file called libgenSub.a under lib/linux-x86/ (gensub support
> directory) that doesn't match with the path followed by the compiler
> (previous error).
> Am I forgetting something?
> Thanks for any help
> - Maurizio M.
Eric Norum
[email protected]
- ioc with genSub record: compiling error Maurizio Montis
Re: [Scopes] BMP image record?? Rod Nussbaumer
RE: [Scopes] BMP image record?? Chen, Xihui
<2012>
2025
2026
Trouble compiling areaDetector1-8beta1 Gessner, Spencer J.
<2012>
2025
2026
