Subject: 'reconnect' in asyn / streamDevice
To: epics <[email protected]>
Date: Fri, 11 May 2012 09:51:38 -0700 (PDT)
I have a webserver type device.
The connection 'breaks' at the end of each successful request.
With asyn autoconnect feature, it seems that at least one request should fail for asyn to attempt to reconnect.
With stream, I intended to use the 'connect 1000' at the beginning of my protocols, but it doesn't seem to work.
(Now that I think of it, maybe I should explicitly disconnect at the end)
So currently I have 50% of my requests that fail.
What is the solution?
Emmanuel
Re: 'reconnect' in asyn / streamDevice Eric Norum
Re: 'reconnect' in asyn / streamDevice Emmanuel Mayssat
Prev: RE: [CA][waveform] how to NELM? Mark Rivers
Next: Re: 'reconnect' in asyn / streamDevice Eric Norum
Prev: Re: [CA][waveform] how to NELM? Pavel Masloff
