Explicit 'disconnect' was required in protocol. FYI. -- Emmanuel From: Emmanuel Mayssat <[email protected]> To: epics <[email protected]> Sent: Friday, May 11, 2012 9:51 AM Subject: 'reconnect' in asyn / streamDevice I have a webserver type device. The connection 'breaks' at the end of each successful request. With asyn autoconnect feature, it seems that at least one request should fail for asyn to attempt to reconnect. With stream, I intended to use the 'connect 1000' at the beginning of my protocols, but it doesn't seem to work. (Now that I think of it, maybe I should explicitly disconnect at the end) So currently I have 50% of my requests that fail. What is the solution? -- Emmanuel
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
