Subject: Re: [CA][waveform] how to NELM?
Date: Sat, 12 May 2012 01:26:14 +0400
Alright, here it works. If someone's interested:
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "cadef.h"
const char *channel_state_str[4] = {
    "not found",
    "connection lost",
    "connected",
    "closed"
typedef struct {
    chid channel;
    int status;
    long value;
} epicsShortPV;
typedef struct {
    chid channel;
    int status;
    long number;
    unsigned short* value;
} epicsWavePV;
/* Connect a PV to a channel */
#define casearch(name, pv) SEVCHK(\
    (pv).status = (ca_search((name), &(pv).channel)), name)
/* get full information about a PV */
#define cainfo(pv, type) SEVCHK(\
    (pv).status = (ca_state((pv).channel) != cs_conn ? ECA_DISCONN : \
    ca_get(dbf_type_to_DBR(type), (pv).channel, &(pv).value)), ca_name((pv).channel))
/* get only usually changing information about a PV */
#define caget(pv, type) SEVCHK(\
    ca_get(dbf_type_to_DBR_STS(type), (pv).channel, &(pv).data)), ca_name((pv).channel))
void printPV(const epicsShortPV* pv)
    if (ca_state(pv->channel) == cs_conn)
        printf("%s =  %d \n", ca_name(pv->channel), pv->value);
    else
        printf("%s: <%s>\n",ca_name(pv->channel), channel_state_str[ca_state(pv->channel)]);
int main(int argc,char** argv)
    int i;
    char* pValue;
    epicsShortPV nelm, nord;
    epicsWavePV wave;
    double search_timeout = 5.0;
    double get_timeout = 1.0;
    ca_task_initialize();
    casearch("file.NELM", nelm);
    casearch("file.NORD", nord);
    casearch("file", wave);
    SEVCHK(ca_pend_io(search_timeout), "casearch");
    /*ca_get(dbf_type_to_DBR(DBR_LONG),nelm.channel,(void*)&nelm.value);
    ca_get(dbf_type_to_DBR(DBR_LONG),nord.channel,(void*)&nord.value);*/
    cainfo(nelm, DBF_LONG);
    cainfo(nord, DBF_LONG);
        ca_array_get(DBR_CHAR, 10, wave.channel, (char*)&wave.value);
        SEVCHK(ca_pend_io(get_timeout), "cainfo");
    printPV(&nelm);
    printPV(&nord);
    pValue = & wave.value;
    for(i=0;i<10;i++)        printf("%d ", pValue[i]);
    ca_task_exit();
        return 0;
One thing I can't get, though everything works fine. The compiler goes with a warning at the line pValue = & wave.value :
warning C4047: '=' : 'char *' differs in levels of indirection from 'unsigned short **'
How can it be fixed (if nesessary)?
Thanks.
On Fri, May 11, 2012 at 7:32 PM, Mark Rivers <[email protected]> wrote:
I don't have much experience with writing CA clients in C, I mostly use IDL, Java, Python, etc.  Perhaps someone else can help.
Sent: Friday, May 11, 2012 9:07 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Thanks, Mark! It works if I am reading just one PV. But when I am reading 2 PVs - (waveform and NELM), my NELM value is enormously big!!!
How can I read several PVs?
This is my code:
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "cadef.h"
int main(int argc,char **argv)
   int data;         /* NELM */
   chid mychid;
   chid chan;        /* WAVEFORM - file*/
   int status;
   unsigned elementCount, nBytes, i;
   struct dbr_time_char * pTD;
   const dbr_char_t * pValue;
   SEVCHK(ca_context_create(ca_disable_preemptive_callback),"ca_context_create");
   SEVCHK(ca_create_channel("file.NORD",NULL,NULL,10,&mychid),"ca_create_channel failure");
   SEVCHK(ca_pend_io(1.0),"ca_pend_io failure");
   SEVCHK(ca_get(DBR_INT,mychid,(void *)&data),"ca_get failure");
   printf("file.NORD: %d\n",data);
   ca_clear_channel ( mychid );
   ca_task_exit ();
   status = ca_create_channel ( argv[1], 0, 0, 0, & chan );
   ca_search(argv[1], &chan);
   SEVCHK ( status, "ca_create_channel()" );
   status = ca_pend_io ( 1.0 );
   if ( status != ECA_NORMAL ) {
       fprintf ( stderr, "\"%s\" not found.\n", argv[1] );
       return -1;
   elementCount = ca_element_count ( chan );
   nBytes = dbr_size_n ( DBR_TIME_CHAR, elementCount );
   pTD = ( struct dbr_time_char * ) malloc ( nBytes );
   if ( ! pTD ) {
       fprintf ( stderr, "insufficient memory to complete request\n" );
       return -1;
   status = ca_array_get (DBR_TIME_CHAR, elementCount, chan, pTD );
   SEVCHK ( status, "ca_array_get()" );
       fprintf ( stderr, "\"%s\" didnt return a value.\n", argv[1] );
       return -1;
   pValue = & pTD->value;
   for ( i = 0; i < 10; i++ )    printf("%d ", pValue[i]);
   printf("\nTotal size: %d\n", elementCount);
   printf("Timestamp: %d\n", pTD->stamp.nsec);
   ca_clear_channel ( chan );
   free ( pTD );
   return(0);
On Fri, May 11, 2012 at 3:42 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
You can just do a ca_get of record.NELM.
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Pavel Masloff [[email protected]<mailto:[email protected]>]
Sent: Friday, May 11, 2012 6:39 AM
To: EPICS Tech Talk
Subject: [CA][waveform] how to NELM?
I am writing a simple CA client in C.
The client reads the waveform record. And I need to know how many elements there are in it (NELM field).
There is a function entitled ca_element_count() which happens to read the NORD field.
Does anybody know how can I get the NELM field ?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
Re: [CA][waveform] how to NELM? Pavel Masloff
RE: [CA][waveform] how to NELM? Mark Rivers
Prev: Channel Access monitoring tools Bill Lavender
Next: New QTi-talk mailing list Andrew Johnson
Prev: RE: [CA][waveform] how to NELM? Mark Rivers
Next: Re: [CA][waveform] how to NELM? Pavel Masloff
