Subject: using Makefile wildcard for installing templates, substitutions
To: Tech Talk <[email protected]>
Date: Wed, 16 May 2012 11:24:56 +0200
I'm trying to add bunch of template and substitution files to DB variable inside my <app>/Db/Makefile, for them to be installed to db folder.
If I list each file separately template and substitution files are installed - I would expect the same using $(wildcard *.template) and $(wildcard *.substitutions) directives, but to no avail - the files are not installed into db folder.
WORKS:
DB += foo.template foo.substitutions bar.template bar.substitutions
DOES NOT WORK:
DB += $(wildcard *.template) $(wildcard *.substitutions)
I've checked the $(DB) after the calls to wildcard, and all the files seem to be listed there, but they do not get installed.
Thank you!
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
Re: using Makefile wildcard for installing templates, substitutions Michael Davidsaver
Prev: Re: using areaDetector as a support library only Bruce Hill
Next: Problem in using synApp sunjl
Next: Re: using Makefile wildcard for installing templates, substitutions Michael Davidsaver
