Subject: Re: using Makefile wildcard for installing templates, substitutions
To: [email protected]
Date: Wed, 16 May 2012 09:42:30 -0400
Try
DB += $(wildcard ../*.template) $(wildcard ../*.substitutions)
Keep in mind that the rules for a particular directory are actually executed in the O.$(T_A) subdirectory.
Michael
On 5/16/2012 5:24 AM, Hinko Kocevar wrote:
I'm trying to add bunch of template and substitution files to DB variable inside my <app>/Db/Makefile, for them to be installed to db folder.
If I list each file separately template and substitution files are installed - I would expect the same using $(wildcard *.template) and $(wildcard *.substitutions) directives, but to no avail - the files are not installed into db folder.
WORKS:
DB += foo.template foo.substitutions bar.template bar.substitutions
DOES NOT WORK:
DB += $(wildcard *.template) $(wildcard *.substitutions)
I've checked the $(DB) after the calls to wildcard, and all the files seem to be listed there, but they do not get installed.
Thank you!
Re: using Makefile wildcard for installing templates, substitutions Hinko Kocevar
Prev: Problem in using synApp sunjl
Next: Re: using Makefile wildcard for installing templates, substitutions Hinko Kocevar
Prev: using Makefile wildcard for installing templates, substitutions Hinko Kocevar
