Subject: RE: [CA][waveform]max array bytes on IOC
To: "'Pavel Masloff'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 18 May 2012 14:35:47 +0000
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [CA][waveform]max array bytes on IOC Pavel Masloff
Prev: Re: [CA][waveform]max array bytes on IOC J. Lewis Muir
Next: RE: using areaDetector as a support library only Mark Rivers
Next: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
