Subject: Re: [CA][waveform]max array bytes on IOC
Date: Sat, 19 May 2012 17:29:04 +0400
I didn't mention it but I did set the EPICS_CA_MAX_ARRAY_BYTES variable both on server and client, and yes I use the root account. Moreover, when I set the variable in /root/.bashrc, before running the IOC, I double check by issuing the command:
echo $EPICS_CA_MAX_ARRAY_BYTES
And it prints it as expected. However, in the client application (either CSS or caget) it either flashes red (PV disconnected) or in case of caget says something like:
CA error The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
When I delete the EPICS_CA_MAX_ARRAY_BYTES variable declaration from /root/.bashrc and explicitly set it in the same terminal window following running the IOC, then everything works fine.
Very strange.
And the machine is SL 5.5, if it's the case.
On Fri, May 18, 2012 at 6:35 PM, Mark Rivers <[email protected]> wrote:
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
[CA][waveform]max array bytes on IOC Pavel Masloff
RE: [CA][waveform]max array bytes on IOC Mark Rivers
Prev: [edm] error Pavel Masloff
Next: [CSS] commas in TextUpdate Pavel Masloff
Prev: RE: [CA][waveform]max array bytes on IOC Mark Rivers
Next: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
