1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VMware : won't allow cagets
To: Mogamad Amien Crombie <[email protected]>
Cc: [email protected]
Date: Mon, 21 May 2012 14:39:23 +0400
Hello Amien
I don't usually use NAT (VMware+RHEL5.5). I prefer either "Host only" or "Bridged" connection. That's the easiest way out.
However, if you prefer NAT over those, I would recommend you look into Edit->Virtual Network Editor and Edit the "Subnet/IP" and "Subnet mask" fields, so they will fit your Ubuntu network preferences.
From your message I presume you have EPICS base installed on the host system (win64). I would first test everything under Windows - create an example application, run it and caget/caput/camonitor from a different command shell.
Then try to ping your virtual machine from Windows and vice versa - both system should see each other. You might as well set the EPICS_CA_AUTO_ADDR_LIST=no and EPICS_CA_ADDR_LIST=xxx.xxx.xxx.xxx environmental variables on your Windows machine, where xxx.xxx.xxx.xxx is the ip-address of your Ubuntu machine.
Or if your Ubuntu is your client then you should make everything the other way around.
HTH
On Mon, May 21, 2012 at 12:31 PM, Mogamad Amien Crombie <[email protected]> wrote:
Hi
I'm using VMWare Workstation 8 inside my Win64 machine with Ubuntu 12.04 LTS running as my virtual machine.
I'm using VMWare's NAT ethernet protocol but cannot do any CAGET/CAPUT/CAMONITORS etc from this virtual machine.
Any help would be appreciated.
Amien
Cape Town
South Africa
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
VMware : won't allow cagets Mogamad Amien Crombie
Prev: VMware : won't allow cagets Mogamad Amien Crombie
Next: Re: [CSS] commas in TextUpdate Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VMware : won't allow cagets Mogamad Amien Crombie
