1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CSS] commas in TextUpdate
To: Pavel Masloff <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 21 May 2012 08:54:33 -0400
What do you get from a command-line camonitor?
I think the issue is this:
The Channel Access network protocol doesn't know about record types, NELM,
NORD, waveform record, ...
All we see is a channel with an array of strings.
On the IOC, the NORD may change, but that doesn't affect the size of the
Channel Access array that's transferred.
The CSS BOY text update widget still gets the full NELM array and it shows
the string value by displaying each element, comma-separated.
See also http://www.aps.anl.gov/epics/tech-talk/2010/msg00720.php :
"Channel access clients receive the size information when they connect.
There is no support in Channel Access for dynamic array sizes."
With CSS BOY you could use a script to hack around this:
Read the actual PV, create a string with only the non-empty array elements
and display that as the text update's value.
But it might be better to work around this further down on the IOC:
Create just one string with the text that you want.
Since a stringin/stringout record is limited to 40 chars, use a waveform
of CHAR for that custom text.
Kay
To:  "[email protected]" <[email protected]>
Subject:  [CSS] commas in TextUpdate
Why I see commas in the TextUpdate widget displaying a waveform when
NELM>NORD??
For example, I have a waveform of strings. NELM=10, NORD=3. As a result:
text1, text2, text3,,,,,,,
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [CSS] commas in TextUpdate Pavel Masloff
Re: [CSS] commas in TextUpdate Ralph Lange
Prev: Re: VMware : won't allow cagets Pavel Masloff
Next: RE: [CSS] commas in TextUpdate Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [CSS] commas in TextUpdate Pavel Masloff
Next: Re: [CSS] commas in TextUpdate Pavel Masloff
