Subject: Re: [CA][waveform]max array bytes on IOC
Date: Tue, 22 May 2012 22:20:06 +0400
THe solution was to put everything in /etc/bashrc.
Thanks Lewis.
On Mon, May 21, 2012 at 11:20 AM, Pavel Masloff <[email protected]> wrote:
Mark,
it's missing in epicsPrtEnvParams !!!
Then I stop the IOC -> issue export EPICS_CA_MAX_ARRAY_BYTES=50000 -> start the IOC -> epicsPrtEnvParams. And now it's there.
Mystic...
On Fri, May 18, 2012 at 6:35 PM, Mark Rivers <[email protected]> wrote:
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
[CA][waveform]max array bytes on IOC Pavel Masloff
RE: [CA][waveform]max array bytes on IOC Mark Rivers
Re: [CA][waveform]max array bytes on IOC Pavel Masloff
Prev: New sequencer snapshot / release candidate Benjamin Franksen
Next: Modbus R2-4 available Mark Rivers
Prev: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
Next: [edm] error Pavel Masloff
