On 2012-05-30 Ralph Lange wrote:
> Of course, any CA client may decide to use any format to write the data.
> It's just the stupid caput tool that always uses DBR_STRING for
> everything it writes.
As long as you're not doing this on Windows (the CA Perl library is too hard
to build for that platform so the Perl scripts are not available there) the
caput.pl script will default to using the channel's native type when putting
array data. The main difference between caput.pl and caput is that caput.pl
does not expect the array length to precede the data, but otherwise the two
are very similar.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Problem when caput to waveform record 王林
- Re: Problem when caput to waveform record Ralph Lange
RE: [StreamDevice] parsing rapid inputs Mark Rivers
Re: Proposed change in asyn - request for comments Ernest L. Williams Jr.
<2012>
2025
2026
Re: Problem when caput to waveform record 王林
ether_ip problem reading DINT arrays Bob Gunion
<2012>
2025
2026
