Subject: Re: calc VAL field not updating from bi VAL field
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 30 May 2012 11:37:38 -0700
On May 30, 2012, at 10:25 AM, Tim Mooney wrote:
> It seems that the integer to double conversion really is not exact for 1.
That seems like a pretty huge flaw in the architecture!  I've never encountered a machine with arithmetic that bad!
I suspect the problem is somewhere else.    Could it be that the bi record is accepting any non-zero value as 'true' -- so that when read as an integer the value is not '1' as the code expects?
>  If so, it wouldn't be exact for either 1.
> Could you try "nint(a)=nint(1)?1:0"
Eric Norum
[email protected]
Re: calc VAL field not updating from bi VAL field Maren Purves
Re: calc VAL field not updating from bi VAL field Tim Mooney
Prev: Re: Proposed change in asyn - request for comments Eric Norum
Next: RE: Proposed change in asyn - request for comments Allison, Stephanie
Prev: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Next: Re: calc VAL field not updating from bi VAL field Maren Purves
