On May 30, 2012, at 6:53 PM, Kim, Kukhee wrote:
> Hi Mark;
> I just read this mail thread.
>> - asyn device support sets the record timestamps based on pasynUser->timeStamp if the following are both true:
>> - The record TSE field is set to epicsTimeEventDeviceTime (-2)
>> - pasynUser->timeStamp is non-zero
Actually the asyn devEpics layer is simpler than described above.
- It always sets the record TIME field from the pasynUser->timestamp in the device support interrupt callback or read method then returns to higher level record processing code.
- The record processing code then overwrites the TIME field unless the TSE field is -2.
I've sent a patch file with some proof-of-concept changes. Hopefully Mark will have time to check them and commit the changes to the subversion repository some time next week.
Eric Norum
[email protected]
- Re: Proposed change in asyn - request for comments Andrew Johnson
- Proposed change in asyn - request for comments Mark Rivers
- Re: Proposed change in asyn - request for comments Ernest L. Williams Jr.
- Re: Proposed change in asyn - request for comments Eric Norum
- RE: Proposed change in asyn - request for comments Mark Rivers
- Re: Proposed change in asyn - request for comments Bruce Hill
- RE: Proposed change in asyn - request for comments Kim, Kukhee
errro running "ibtest" tzk6s
Re: [CSS] commas in TextUpdate Pavel Masloff
<2012>
2025
2026
<2012>
2025
2026
