Subject: Re: [CSS] commas in TextUpdate
To: Dirk Zimoch <[email protected]>
Date: Thu, 31 May 2012 12:54:39 +0400
That's right Dirk!
Caget and camonitor do not display commas! (tested on win32 and linux).
Tested with CAJ CA library and the native CA (CSS 3.0.1 on Windows) - same behavior. This must be the widget itself.
Maybe I can truncate my array on the IOC side? The subArray record? (the only question is how?) (Can it receive the NORD field from the actual waveform into its own NELM  field?)
On Wed, May 23, 2012 at 1:53 PM, Dirk Zimoch <[email protected]> wrote:
Steiner, Mathias wrote:
 >> camonitor and caget don't display commas
At least in our installation they do:
caput STRCHAN199 abcdef, ghijk
Old : STRCHAN199
New : STRCHAN199                     abcdef, ghijk
caget STRCHAN199
Here the comma is the last char of the first string. It does not display commas between the strings.
Dirk
Cheers -Mathias
From: [email protected] [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Pavel Masloff
Sent: Monday, May 21, 2012 9:43 AM
To: Kasemir, Kay
Cc: EPICS Tech Talk
On Mon, May 21, 2012 at 5:41 PM, Pavel Masloff <[email protected]> wrote:
Kay, I didn't understand your intent here:
But it might be better to work around this further down on the IOC:
Create just one string with the text that you want.
Since a stringin/stringout record is limited to 40 chars, use a waveform of CHAR for that custom text.
Does it differ from this method? http://www.aps.anl.gov/epics/tech-talk/2010/msg00720.php
I would like it to be truncated on the IOC side.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
RE: [CSS] commas in TextUpdate Chen, Xihui
[CSS] commas in TextUpdate Pavel Masloff
Re: [CSS] commas in TextUpdate Kasemir, Kay
Re: [CSS] commas in TextUpdate Pavel Masloff
RE: [CSS] commas in TextUpdate Steiner, Mathias
Re: [CSS] commas in TextUpdate Dirk Zimoch
Prev: Re: Proposed change in asyn - request for comments Eric Norum
Next: Re: [CSS] commas in TextUpdate Pavel Masloff
Prev: Re: [CSS] commas in TextUpdate Dirk Zimoch
Next: RE: [CSS] commas in TextUpdate Chen, Xihui
