1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposed change in asyn - request for comments
Cc: [email protected]
Date: Thu, 31 May 2012 10:20:50 -0700
On May 31, 2012, at 9:17 AM, Andrew Johnson wrote:
> You wrote "device support interrupt callback or read method", which I
> originally read as the ISR, but it would be just as bad to set the TIME field
> in the port thread or a callback routine without first locking the lockset.
> If you meant that TIME gets set by the dset->read_xxx() routine then that's
> fine, because it gets called by the record's process routine with the lockset
> locked.  I wasn't really thinking about the limitations of interrupt context,
> it's that accessing a record's fields from any thread that has not first
> locked the record's lockset is not safe.
Right -- the actual setting of the .TIME field is done by the various devEpics  dset->read_xxx() routines.
Sorry to have implied anything different.
Proposed change in asyn - request for comments Mark Rivers
Re: Proposed change in asyn - request for comments Andrew Johnson
Re: Proposed change in asyn - request for comments Eric Norum
Prev: Re: Proposed change in asyn - request for comments Andrew Johnson
Next: waveform of STRING memory structure Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Proposed change in asyn - request for comments Bruce Hill
