1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposed change in asyn - request for comments
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Thu, 31 May 2012 11:17:06 -0500
Hi Eric,
On 2012-05-31 Eric Norum wrote:
> On May 31, 2012, at 8:08 AM, Andrew Johnson wrote:
> > On 2012-05-30 Eric Norum wrote:
> >> Actually the asyn devEpics layer is simpler than described above.
> >> - It always sets the record TIME field from the pasynUser->timestamp in
> >> the device support interrupt callback or read method then returns to
> >> higher level record processing code.
> >> - The record processing code then
> >> overwrites the TIME field unless the TSE field is -2.
> Who said that we were doing this from an ISR?
> I guess that I wasn't clear enough.    The devEPICS code that's writing to
>  the .TIME field is actually in an interrupt callback thread -- at
>  task-level. This is acceptable isn't it?
You wrote "device support interrupt callback or read method", which I
originally read as the ISR, but it would be just as bad to set the TIME field
in the port thread or a callback routine without first locking the lockset.
If you meant that TIME gets set by the dset->read_xxx() routine then that's
fine, because it gets called by the record's process routine with the lockset
locked.  I wasn't really thinking about the limitations of interrupt context,
it's that accessing a record's fields from any thread that has not first
locked the record's lockset is not safe.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Proposed change in asyn - request for comments Eric Norum
Proposed change in asyn - request for comments Mark Rivers
Re: Proposed change in asyn - request for comments Andrew Johnson
Prev: Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
Next: Re: Proposed change in asyn - request for comments Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposed change in asyn - request for comments Eric Norum
