Oh, now I understand. One can check by:
if (data[i]!=NULL) {}
or
if (isalnum(data[i]) || isspace(data[i])) {}
Thanks Andrew and Kay!!
Cheers, Pavel
On Fri, Jun 1, 2012 at 12:51 AM, Pavel Masloff <[email protected]> wrote:
Thanks. I checked it out. That's correct. How do clients (IOC subroutines) treat strings which are less than NELM, there will obviously be white spaces (or how is a waveform initialized?)
On Fri, Jun 1, 2012 at 12:42 AM, Andrew Johnson <[email protected]> wrote:
Hi Pavel,
On 2012-05-31 Pavel Masloff wrote:
> How is a waveform of strings represented in memory? As an array of pointers
> to char? Or as NELM consecutive 40 byte chars? Or less than 40 (depending
> on the size of each waveform element).
> This is what Kay suggests:
> *Not sure, but I would assume NELM consecutive 40 byte chars.
> This is how the memory is allocated in the waveform record:
> * * prec->bptr = callocMustSucceed(prec->nelm, dbValueSize(prec->ftvl),
> "waveform calloc failed");
> So it's one long area, and dbValueSize(STRING) is MAX_STRING_SIZE == 40.*
> Is it so?
Kay is correct; all array fields consist of a single buffer containing up to
NELM fixed-length elements. A DBF_STRING is a fixed-length 40-character array
of chars (but just in case some site has privately decided to change the value
of MAX_STRING_SIZE always use that macro instead of the literal 40). Therefor
an array of 10 STRINGs is a 400 character buffer where bytes 0 through 39 hold
the first element, bytes 40 through 79 hold the second and so on.
If what you're storing is really one long character string there is no
advantage in using a waveform of STRING data; it's better to just use a
waveform of CHAR type, which you can then use 'caget -S' to display.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
- waveform of STRING memory structure Pavel Masloff
- Re: waveform of STRING memory structure Andrew Johnson
- Re: waveform of STRING memory structure Pavel Masloff
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
