Subject: Re: waveform of STRING memory structure
To: Pavel Masloff <[email protected]>
Cc: [email protected]
Date: Thu, 31 May 2012 16:08:43 -0500
Hi Pavel,
On 2012-05-31 Pavel Masloff wrote:
> How do clients (IOC subroutines) treat strings which are less than NELM,
> there will obviously be white spaces (or how is a waveform initialized?)
Each individual 40-character string in the array is supposed to have a
terminating 0 byte, although CA may transport all 40 bytes.  Clients should be
prepared to handle values that fill all 40 characters and should terminate the
string after the 40th character if necessary.  Since we use calloc() to
allocate the buffer all elements should start out empty.
Is that what you were asking?
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: waveform of STRING memory structure Pavel Masloff
Re: waveform of STRING memory structure Andrew Johnson
Prev: Re: waveform of STRING memory structure Pavel Masloff
Next: Re: Proposed change in asyn - request for comments Bruce Hill
Next: Re: waveform of STRING memory structure Pavel Masloff
