I am assuming that is defined somewhere?
Looking at the MBBI record definition, I see that Mask, ZRVl, ONVL, … FFVL are all ULONGS, which would allow a bit field to be defined that didn't depend on consecutive bits. Seems that the limitation is that NOBT defines MASK.
If NOBT was set to 0 (I would take that meaning as "don't define mask"), seems MASK 'should' be able to be manipulated.
Looking in the ether-ip driver, it doesn't look like mask from the record is even used. It builds it's own internally.
David
The limit/definition of the MBBx record types was that the bits were consecutive.
I think that you would have to use a calc record between the input and MBBx record to mask out the bits in between.
Bob
- RE: mbbi/mbbo Mask values Dalesio, Leo
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
