Subject: RE: mbbi/mbbo Mask values
To: "Dudley, David" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Jun 2012 12:58:07 +0000
In the record reference manual on the EPICS wiki
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Multi-Bit_Binary_Input
it states:
NOBT Number of Bits Number of hardware bits accessed. They must be consecutive.
It would be better if the introduction to this record type had pointed this out. I will chance that today - if I remember how to get into the wiki page.
Sent: Friday, June 01, 2012 8:42 AM
To: Dalesio, Leo; [email protected]
Subject: Re: mbbi/mbbo Mask values
I am assuming that is defined somewhere?
Looking at the MBBI record definition, I see that Mask, ZRVl, ONVL, … FFVL are all ULONGS, which would allow a bit field to be defined that didn't depend on consecutive bits.  Seems that the limitation is that NOBT defines MASK.
If NOBT was set to 0 (I would take that meaning as "don't define mask"), seems MASK 'should' be able to be manipulated.
Looking in the ether-ip driver, it doesn't look like mask from the record is even used.  It builds it's own internally.
David
Date: Friday, June 1, 2012 8:34 AM
To: David Dudley <[email protected]>, "[email protected]" <[email protected]>
The limit/definition of the MBBx record types was that the bits were consecutive.
I think that you would have to use a calc record between the input and MBBx record to mask out the bits in between.
Bob
Re: mbbi/mbbo Mask values Dudley, David
RE: mbbi/mbbo Mask values Dalesio, Leo
Prev: Re: mbbi/mbbo Mask values Dudley, David
Next: Re: mbbi/mbbo Mask values Dudley, David
