Subject: Re: asynManager isConnected
To: <[email protected]>
Cc: [email protected]
Date: Fri, 1 Jun 2012 09:14:34 -0700
On Jun 1, 2012, at 8:45 AM, <[email protected]> wrote:
> Thanks Lewis, Mark and Eric,
>> I don't know of a function in Asyn that allows one to determine
>> whether the IP socket is connected.  I always just determine
>> this based on the asynStatus returned from a read or write.  But
>> maybe there's a way that I don't know about?
> That's what I was hoping to do too, but I'm not getting a return from the writeRead function. It blocks forever (at least, more than 15 mins) if I attempt a writeRead using the un-connected IP port. Eric suggested this might be due to the operating system timeout on TCP connections (which I gather can be fixed to infinite).
Well, I've never seen anything longer than 60 seconds so that isn't your problem.
> I'm probably doing something wrong, because I have the asynManager isConnected problem too.
> The reason I'm interested in understanding this, rather than just working around it, is because I want to handle connections to ethernet PMAC motor controllers automatically if they come up *after* the IOC has already started. Currently we have to restart an IOC if any of our PMACs come up that were turned off when the IOC was started.
What version of ASYN?
What operating system?
There have been *lots* of changes to the connect code over time.
Eric Norum
[email protected]
asynManager isConnected matthew.pearson
Re: asynManager isConnected J. Lewis Muir
RE: asynManager isConnected matthew.pearson
Prev: Re: mbbi/mbbo Mask values Andrew Johnson
Next: Re: mbbi/mbbo Mask values Ralph Lange
Prev: RE: asynManager isConnected matthew.pearson
Next: RE: asynManager isConnected Mark Rivers
