Subject: Re: mbbi/mbbo Mask values
To: EPICS Tech Talk <[email protected]>
Date: Fri, 01 Jun 2012 18:35:25 +0200
On 01.06.2012 18:02, Andrew Johnson wrote:
> Hi Bob,
> On 2012-06-01 Dalesio, Leo wrote:
>> The wiki page now clearly states in the introduction to the MBBI and MBBO
>>  that the bits must be continuous.
> My point was that the record code doesn't need the bits to be contiguous; it
> will still work properly as long as the result of (RVAL << SHFT) matches one
> of the xxVL field values.  I have no intention of letting anyone change the
> code to break that since there are too many device supports and IOCs out there
> which could be relying on this.
What about allowing MASK to be set in the database, and only setting it
in the init_record() code, if it is 0.
That would not break existing code (or would it?), and provide an easy
way to set MASK directly (contiguous or not), avoiding NOBT and SHFT.
~Ralph
Re: mbbi/mbbo Mask values Dudley, David
Re: mbbi/mbbo Mask values Andrew Johnson
RE: mbbi/mbbo Mask values Dalesio, Leo
Prev: Re: asynManager isConnected Eric Norum
Next: Re: Proposed change in asyn - request for comments Williams Jr., Ernest L.
Prev: Re: mbbi/mbbo Mask values Andrew Johnson
Next: Re: mbbi/mbbo Mask values Dudley, David
