1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposed change in asyn - request for comments
From: "Williams Jr., Ernest L." <[email protected]>
Date: Fri, 1 Jun 2012 09:49:20 -0700
Sent from my iPhone
On Jun 1, 2012, at 7:57 AM, "Andrew Johnson" <[email protected]> wrote:
> Hi Bruce,
> On 2012-05-31 Bruce Hill wrote:
>> My concern was that overloading the TSE field to contain EVR Event codes
>> would be inappropriate for a module like asyn that is used by many sites
>> that don't use EVR's.
> The TSE and TSEL fields were originally /designed/ for use with timing system
> event codes.  The Record Reference Manual describes the TSE field thus:
>    This indicates the mechanism to use to get the time stamp. '0' - call
>    get time as before '-1' - call the time stamp driver and use the best
>    source available. '-2' - the device support provides the time stamp
>    from the hardware. Values between 1-255 request the time of the last
>    occurrence of a generalTime event.
>  https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
> I agree that this mechanism is not currently much use on systems that don't
> use an event timing system, although it would be quite feasible to write a
> plugin for the generalTime event subsystem that provides global event times
> from UDP packets.
That is really a good idea :)
Then windows-based systems can pick up pulseIDs over the network
Or at least for systems that don't have special timing hardware on the client side
Cheers
Ernest
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
Proposed change in asyn - request for comments Mark Rivers
RE: Proposed change in asyn - request for comments Kim, Kukhee
Re: Proposed change in asyn - request for comments Bruce Hill
Re: Proposed change in asyn - request for comments Andrew Johnson
Prev: Re: mbbi/mbbo Mask values Ralph Lange
Next: Re: mbbi/mbbo Mask values Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposed change in asyn - request for comments Andrew Johnson
Next: Re: Proposed change in asyn - request for comments Bruce Hill
