Sorry to have been confused by your original message. I didn't realize that you really did want to cross-compile.
RTEMS tools, core and board-support packages are all available as RPM files with support for APT or Yum.
I know that RTEMS/EPICS for the uC5282 builds without problems on a LInux (or OS X) platform.
Here's what the build output near the link command for the EPICS libCom test harness looks like on my machine:
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=5282 -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include ../epicsMaxThreads.c
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=5282 -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include ../buckTest.c
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems -c -mcpu=5282 -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include ../cvtFastPerform.cpp
../cvtFastPerform.cpp: In member function 'void Test::execute()':
../cvtFastPerform.cpp:63: warning: integer overflow in expression
../cvtFastPerform.cpp:65: warning: integer overflow in expression
../cvtFastPerform.cpp:75: warning: integer overflow in expression
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems -o rtemsTestHarness -static -L/usr/local/epics/R3.14.12/base-3.14.12.2/lib/RTEMS-uC5282 -mcpu=5282 -u Init /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-mp.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-part.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-signal.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-rtmon.rel rtemsTestHarness.o epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o epicsEllTest.o epicsErrlogTest.o epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epicsThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTest.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o epicsMutexTest.o epicsExceptionTest.o macEnvExpandTest.o macLibTe!
st.o taskwdTest.o blockingSockTest.o epicsMessageQueueTest.o epicsRunLibComTests.o epicsThreadPerform.o epicsMaxThreads.o buckTest.o cvtFastPerform.o -lCom -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-objcopy -O binary -R .comment -S rtemsTestHarness rtemsTestHarness.boot
echo "Installing created file ../../../../bin/RTEMS-uC5282/rtemsTestHarness"
echo "Installing created file ../../../../bin/RTEMS-uC5282/rtemsTestHarness.boot"
make -C db/test install
Eric Norum
[email protected]
- EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
- Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Andrew Johnson
- RE: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
error: Command drvAsynIPPortConfigure not found Chen Xue
<2012>
2025
2026
<2012>
2025
2026
