1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks 6.8 & devIocStats
To: [email protected]
Date: Fri, 8 Jun 2012 12:19:29 -0500
On 2012-06-08 Kevin Peterson wrote:
> I'm getting an access fault during iocInit when I load
> iocAdminVxWorks.db from devIocStats:
> My vme is using VxWorks 6.8, base-3.14.12.2, and devIocStats-3-1-7 (from
> synApps_5_6).  The problem also occurs with devIocStats 3.1.9.
> I've used the debugger to trace the fault to the iocInit.c:doRecordPini
> for the record iockmp:DAT_MBUF_MAX.
> The problem doesn't occur with VxWorks 5.5.2.
Has anybody looked at upgrading iocStats for the new network stack in vxWorks
6.8?  Wind River replaced the network stack code and associated buffer pool
(again), such that the code in iocStats/devIocStats/os/vxWorks/osdClustInfo.c
is now wrong; on our vxWorks 6.8 systems both _pNetSysPool and _pNetDpool are
NULL, so neither devIocStatsGetClusterInfo() nor devIocStatsGetClusterUsage()
are correct any more.  For some reason the APS Controls IOCs that have loaded
iocStats have not been crashing when they initialize the record that Kevin
mentions above, but his IOC (using the same vxWorks OS configuration, but a
different CPU board) does crash.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
VxWorks 6.8 & devIocStats Kevin Peterson
Prev: VxWorks 6.8 & devIocStats Kevin Peterson
Next: RE: ASYN 4-19 createParam return status Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Runaway connection count on IOC michael.abbott
