Hi Hinko,
Thanks for finding this problem. I have applied the patch, which will be in the next release of asyn.
From: [email protected] [[email protected]] on behalf of Hinko Kocevar [[email protected]]
Sent: Tuesday, June 05, 2012 2:18 AM
To: EPICS Tech Talk
Subject: ASYN 4-19 createParam return status
I've found a potential problem in the Asyn 4-19 (I think that 4-18 has
the same problem) when calling createParam() with the existing parameter
string (already in the list).
The return value of findParam() and createParam() in
asynPortDriver::createParam() is not tested properly and error is never
caught. I believe that the call to findParam() can be omitted. Only call
to createParam() is needed and return status compared with
asynParamBadIndex and asynParamAlreadyExists afterwards.
Here is the patch.
### Eclipse Workspace Patch 1.0
#P kofein-epics-ioc
Index:
3rdParty/extensions/src/asyn4-19/asyn/asynPortDriver/asynPortDriver.cpp
(revision 16365)
(working copy)
@@ -99,17 +99,15 @@
asynStatus asynPortDriver::createParam(int list, const char *name,
asynParamType type, int *index)
asynStatus status;
- int itemp;
static const char *functionName = "createParam";
- status = this->params[list]->findParam(name, &itemp);
+ status = this->params[list]->createParam(name, type, index);
if (status == asynParamAlreadyExists) {
asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: port=%s error adding parameter %s to list %d,
parameter already exists.\n",
driverName, functionName, portName, name, list);
return(asynError);
- status = this->params[list]->createParam(name, type, index);
if (status == asynParamBadIndex) {
"%s:%s: port=%s error adding parameter %s to list %d, too
many parameters\n",
Best regards,
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si - When your users demand stability
- ASYN 4-19 createParam return status Hinko Kocevar
Re: VxWorks 6.8 & devIocStats Andrew Johnson
Re: EPICS host architectures Andrew Johnson
<2012>
2025
2026
mask for bitwise operation in CALC record haquin
<2012>
2025
2026
