1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASYN 4-19 createParam return status
To: EPICS Tech Talk <[email protected]>
Date: Tue, 05 Jun 2012 09:18:54 +0200
I've found a potential problem in the Asyn 4-19 (I think that 4-18 has the same problem) when calling createParam() with the existing parameter string (already in the list).
The return value of findParam() and createParam() in asynPortDriver::createParam() is not tested properly and error is never caught. I believe that the call to findParam() can be omitted. Only call to createParam() is needed and return status compared with asynParamBadIndex and asynParamAlreadyExists afterwards.
Here is the patch.
### Eclipse Workspace Patch 1.0
#P kofein-epics-ioc
Index: 3rdParty/extensions/src/asyn4-19/asyn/asynPortDriver/asynPortDriver.cpp
--- 3rdParty/extensions/src/asyn4-19/asyn/asynPortDriver/asynPortDriver.cpp (revision 16365) +++ 3rdParty/extensions/src/asyn4-19/asyn/asynPortDriver/asynPortDriver.cpp (working copy)
@@ -99,17 +99,15 @@
asynStatus asynPortDriver::createParam(int list, const char *name, asynParamType type, int *index)
     asynStatus status;
-    int itemp;
     static const char *functionName = "createParam";
-    status = this->params[list]->findParam(name, &itemp);
+    status = this->params[list]->createParam(name, type, index);
     if (status == asynParamAlreadyExists) {
         asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: port=%s error adding parameter %s to list %d, parameter already exists.\n",
             driverName, functionName, portName, name, list);
         return(asynError);
-    status = this->params[list]->createParam(name, type, index);
     if (status == asynParamBadIndex) {
"%s:%s: port=%s error adding parameter %s to list %d, too many parameters\n",
Best regards,
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si - When your users demand stability
RE: ASYN 4-19 createParam return status Mark Rivers
Prev: Re: [StreamDevice] ? Pavel Masloff
Next: mask for bitwise operation in CALC record haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: counter of clients for specific PV in IOC Andrew Johnson
Next: RE: ASYN 4-19 createParam return status Mark Rivers
