Subject: RE: BOY XY graph tick marks [SEC=UNCLASSIFIED]
To: "LYNCH, Damien" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Jun 2012 11:10:02 -0400
Hi Damien,
In most cases, if you set X axis range to a multiple of 14, for example, [0,14,], [0,140], or [10,150], it will give you 14 vertical divisions. If it is not 14 vertical divisions, you can adjust the width of XYGrpah to make it. Similar to the Y axis.
Also, you need to set "Auto Scale" to No.  If you have arbitrary range on Axis, that would be very hard or impossible to have 14 divisions.
Xihui
Sent: Tuesday, June 19, 2012 12:57 AM
To: [email protected]
Subject: BOY XY graph tick marks [SEC=UNCLASSIFIED]
Is there a way to specify the tick marks in an XY graph? For example I am using the XY graph  widget to replicate an oscilloscope display that has 8 horizontal divisions and 14 vertical divisions.
Damien
BOY XY graph tick marks [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: Re: Strange performance results -- any ideas? Till Straumann
Next: Re: Strange performance results -- any ideas? Matthieu Bec
Prev: BOY XY graph tick marks [SEC=UNCLASSIFIED] LYNCH, Damien
Next: RE: BOY XY graph tick marks [SEC=UNCLASSIFIED] Chen, Xihui
