Yes, you are exactly right! The tick marks is multiples of 5 or 10, so it can be easily read. Another way might be draw these division lines using polyline widget and set XY Graph "transparent" property to yes.
Cheers,
Xihui
> -----Original Message-----
> From: LYNCH, Damien [mailto:[email protected]]
> Sent: Tuesday, June 19, 2012 6:35 PM
> To: Chen, Xihui; [email protected]
> Subject: RE: BOY XY graph tick marks [SEC=UNCLASSIFIED]
> Hi Xihui,
> Thanks for the tip. Resizing the widget did allow me to get the 14
> divisions on the x-axis (which has a range of 700). I couldn't get the
> y-axis split into 8 divisions though. The range of that axis is 256 and
> it looks like the tick marks will be set to multiples of 5 or 10 but
> nothing in between. We can live with that though.
> Thanks,
> Damien
> > From: Chen, Xihui [mailto:[email protected]]
> > Sent: Wednesday, 20 June 2012 1:10 AM
> > To: LYNCH, Damien; [email protected]
> > Hi Damien,
> > In most cases, if you set X axis range to a multiple of 14, for
> > example, [0,14,], [0,140], or [10,150], it will give you 14 vertical
> > divisions. If it is not 14 vertical divisions, you can adjust the
> > width of XYGrpah to make it. Similar to the Y axis.
> > Also, you need to set "Auto Scale" to No. If you have arbitrary
> range
> > on Axis, that would be very hard or impossible to have 14 divisions.
> > Thanks,
> > Xihui
> > ________________________________________
> > From: LYNCH, Damien [[email protected]]
> > Sent: Tuesday, June 19, 2012 12:57 AM
> > To: [email protected]
> > Subject: BOY XY graph tick marks [SEC=UNCLASSIFIED]
> > Hi,
> > Is there a way to specify the tick marks in an XY graph? For example
> I
> > am using the XY graph widget to replicate an oscilloscope display
> > that has 8 horizontal divisions and 14 vertical divisions.
> > Thanks,
> > Damien
- BOY XY graph tick marks [SEC=UNCLASSIFIED] LYNCH, Damien
- RE: BOY XY graph tick marks [SEC=UNCLASSIFIED] Chen, Xihui
Re: Strange performance results -- any ideas? Burkhard Kolb
dbd expand errors for measurementComputing module S. Stein
<2012>
2025
2026
Strange performance results -- any ideas? Dirk Zimoch
<2012>
2025
2026
