1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP
To: [email protected]
Cc:
Date: Thu, 21 Jun 2012 20:57:50 +0900
Hello,
I want to have a target IOC for mvme5100 using cygwin and vxWorks5.5 (Tornado2.2) on Windows XP.
My base compile produces only cygwin-x86 binary and library files, such as $EPISC_BASE/bin/cygwin-x86 and $EPISC_BASE/lib/cygwin-x86.
There is no vxWorks-ppc604 binary and library for target board.
The compile environment is below.
- C:\cygwin
- C:\Tornado2.2
- C:\epics\base3.14.9 ~ 3.14.11.
EPICS environment variables in .bash_profile under cygwin root:
- .base_profile
  : export EPICS_BASE=/cygdrive/c/epics/base-3.14.11
  : export EPICS_HOST_ARCH=cygwin-x86
  : export WIND_BASE=/cygdrive/c/Tornado2.2
  : export WIND_HOST_TYPE=x86-win32
I edited base config files below.
- configure/CONFIG_SITE
  : CROSS_COMPILER_TARGET_ARCH=vxWorks-ppc604
- configure/os/CONFIG_SITE.Common.vxWorksCommon
  : VXWORKS_VERSION=5.5
  : WIND_BASE=/cygdrive/c/Tornado2.2
I have no experience of a cross-compile environment using cygwin and vxWorks.
I can't guess this problem.
Is this problem the environment variable setting?
Will it be able to set up a cross-compile environment with cygwin and vxWorks or not?
Awaiting for an response from you,
Thanks in advance,
With all my regards,
Young-gi
Re: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP Andrew Johnson
Prev: Employment Opportunities at FRIB John A. Priller
Next: put callback queuing Daron Chabot
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP Andrew Johnson
