For the first time in our experience, we have a serial device (Kepco power supply) that insists on sending XOFF/XON sequences. We are using streamDevice and a Greenspring Octal IP module to talk to it. StreamDevice and Asyn
appear to have no problems with the XOFF/XON characters, however the tyGSOctalStartup routine in tyGSOctal.c puts out a continuous stream of
"tyITX ERROR, sr=0c" errors. The cause of these errors turns out to be
that the tyITx() routine (a vxWorks function) returns ERROR if it is called to start a transmission and the transmitter is XOFF'd.
This causes the tyGSOctalStartup routine to log an error -- perhaps because it thinks someone is trying to send a zero-length buffer (no characters left to transmit is the other reason tyITx() will return
ERROR).
The easiest way to fix the problem was just to remove the error message (see attached patch file -- which only comments out the offending code in case that turns out to be a bad idea). As far as we
can tell, there are no ill effects from this. We seem to be talking to the power supply just fine.
Anybody see a reason why we should leave the error report in tyGSOctalStartup() ?
-Eric Bj
tyGSOctal.patch
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
