1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS and MEDM on ubuntu
To: [email protected]
Date: Sun, 24 Jun 2012 15:52:44 +0530
Hi Everyone,
I am new to EPICS and i am trying to install EPICS and medm on ubuntu
linux 10.04. I use your method as a guide in installation.
when i am compiling epics following output appears and when trying to
compile MEDM also following output results. I really appreciate if you
could support me to make this work.
Thank you
Screen that appears after compiling  MEDM
nalaka@nalaka-laptop:/opt/epics/extensions/src/medm$ make
make -C ./printUtils install
make[1]: Entering directory
`/opt/epics/extensions/src/medm3_1_4/printUtils'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory
`/opt/epics/extensions/src/medm3_1_4/printUtils/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory
make[1]: Leaving directory
make -C ./xc install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/xc'
`/opt/epics/extensions/src/medm3_1_4/xc/O.linux-x86'
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/xc'
make -C ./medm install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/medm'
`/opt/epics/extensions/src/medm3_1_4/medm/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32
-g  -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux
-I../../../../include -I/opt/epics/base/include/os/Linux
-I/opt/epics/base/include        -I../../printUtils -I../../xc
-I/usr/include -I/usr/include/X11    ../medmCartesianPlot.c
In file included from ../medm.h:104,
                 from ../medmCartesianPlot.c:58:
../medmCA.h:34:19: error: cadef.h: No such file or directory
../medmCA.h:35:23: error: db_access.h: No such file or directory
../medmCA.h:36:50: error: alarm.h: No such file or directory
../medmCA.h:48: error: field ‘s’ has incomplete type
../medmCA.h:49: error: field ‘e’ has incomplete type
../medmCA.h:50: error: field ‘c’ has incomplete type
../medmCA.h:51: error: field ‘i’ has incomplete type
../medmCA.h:52: error: field ‘l’ has incomplete type
../medmCA.h:53: error: field ‘f’ has incomplete type
../medmCA.h:54: error: field ‘d’ has incomplete type
../medmCA.h:69: error: field ‘s’ has incomplete type
../medmCA.h:70: error: field ‘e’ has incomplete type
../medmCA.h:71: error: field ‘c’ has incomplete type
../medmCA.h:72: error: field ‘i’ has incomplete type
../medmCA.h:73: error: field ‘l’ has incomplete type
../medmCA.h:74: error: field ‘f’ has incomplete type
../medmCA.h:75: error: field ‘d’ has incomplete type
../medmCA.h:94: error: expected specifier-qualifier-list before
‘TS_STAMP’
../medmCA.h:109: error: expected specifier-qualifier-list before ‘chid’
In file included from ../medmCartesianPlot.c:73:
../medmCartesianPlot.h:83: error: expected specifier-qualifier-list
before ‘TS_STAMP’
../medmCartesianPlot.c: In function
‘cartesianPlotCreateRunTimeInstance’:
../medmCartesianPlot.c:193: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:194: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:195: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
‘cartesianPlotUpdateGraphicalInfoCb’:
../medmCartesianPlot.c:360: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cartesianPlotUpdateTrace’:
../medmCartesianPlot.c:415: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c:546: error: ‘DBF_STRING’ undeclared (first use in
this function)
../medmCartesianPlot.c:546: error: (Each undeclared identifier is
reported only once
../medmCartesianPlot.c:546: error: for each function it appears in.)
../medmCartesianPlot.c:554: error: ‘DBF_INT’ undeclared (first use in
this function)
../medmCartesianPlot.c:563: error: ‘DBF_FLOAT’ undeclared (first use in
this function)
../medmCartesianPlot.c:572: error: ‘DBF_ENUM’ undeclared (first use in
this function)
../medmCartesianPlot.c:581: error: ‘DBF_CHAR’ undeclared (first use in
this function)
../medmCartesianPlot.c:590: error: ‘DBF_LONG’ undeclared (first use in
this function)
../medmCartesianPlot.c:592: error: ‘dbr_long_t’ undeclared (first use in
this function)
../medmCartesianPlot.c:592: error: ‘pLong’ undeclared (first use in this
function)
../medmCartesianPlot.c:592: error: expected expression before ‘)’ token
../medmCartesianPlot.c:599: error: ‘DBF_DOUBLE’ undeclared (first use in
this function)
../medmCartesianPlot.c:643: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:645: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:646: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:646: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:648: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:649: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:650: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:674: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:682: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:683: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:759: error: expected expression before ‘)’ token
../medmCartesianPlot.c:836: error: expected expression before ‘)’ token
../medmCartesianPlot.c:920: error: expected expression before ‘)’ token
../medmCartesianPlot.c:968: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:969: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:971: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:972: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:974: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:976: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:982: error: expected expression before ‘)’ token
../medmCartesianPlot.c:983: error: expected ‘;’ before ‘offset’
../medmCartesianPlot.c:987: error: ‘offset’ undeclared (first use in
this function)
../medmCartesianPlot.c:997: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:1069: error: expected expression before ‘)’ token
‘cartesianPlotUpdateScreenFirstTime’:
../medmCartesianPlot.c:1103: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cartesianPlotUpdateValueCb’:
../medmCartesianPlot.c:1245: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cpAxisOptionMenuSimpleCallback’:
../medmCartesianPlot.c:2252: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:2259: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:2269: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
make[2]: *** [medmCartesianPlot.o] Error 1
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/medm'
make: *** [medm.install] Error 2
Screen that appears after compiling EPICS
nalaka@nalaka-laptop:/opt/epics/base$ make
make -C ./configure install
make[1]: Entering directory `/opt/epics/base-3.14.10/configure'
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
`/opt/epics/base-3.14.10/configure/O.linux-x86'
make[1]: Leaving directory `/opt/epics/base-3.14.10/configure'
make -C ./src install
make[1]: Entering directory `/opt/epics/base-3.14.10/src'
make -C ./tools install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/tools'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/opt/epics/base-3.14.10/src/tools/O.linux-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/tools'
make -C ./makeBaseApp install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/makeBaseApp'
`/opt/epics/base-3.14.10/src/makeBaseApp/O.linux-x86'
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/makeBaseApp'
make -C ./makeBaseExt install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/makeBaseExt'
`/opt/epics/base-3.14.10/src/makeBaseExt/O.linux-x86'
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/makeBaseExt'
make -C ./libCom install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/libCom'
`/opt/epics/base-3.14.10/src/libCom/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I.
-I../O.Common -I. -I../../../src/libCom/osi/os/Linux
-I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I../../../include/os/Linux
-I../../../include         ../../../src/libCom/ring/epicsRingPointer.cpp
make[3]: /usr/bin/g++: Command not found
make[3]: *** [epicsRingPointer.o] Error 127
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/opt/epics/base-3.14.10/src'
make: *** [src.install] Error 2
Re: EPICS and MEDM on ubuntu Dirk Zimoch
Prev: Processing And Visualization of time series data. Mihaylov, Miroslav N.
Next: XOFF Problem with tyGSOctal Bjorklund, Eric A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Processing And Visualization of time series data. Miroslav Mihaylov
Next: Re: EPICS and MEDM on ubuntu Dirk Zimoch
