Subject: epicsAtExit
To: Mark Rivers <[email protected]>, "Williams Jr., Ernest L." <[email protected]>
Date: Wed, 27 Jun 2012 17:40:06 -0700
Hi Mark,
I have a problem, which I have been ignoring for a while.
I have a device driver for a VME module based on asynPortDriver class.  It is used with asyn R4.18, EPICS R3.14.12.2, vxWorks 6.6.
I have coded a couple of routines to disable interrupts when the IOC is shutdown (with CTRL-X), which does not work.  Restarting the IOC which uses the asyn based driver with CTRL-X fails to come up.  The IOC reaches some point in the booting sequence and then I suppose it crashes because the boot starts all over.  I recover from that with a VME reset.  Also, if I disable interrupts before rebooting all works fine.
I have created another device driver using the conventional approach, which does not use asyn.  As far as I can tell most of the code if not the same is equivalent.  With this device driver the interrupts get disabled on exit.
This is what I have in the asynPortDriver version of the device driver:
In the constructor I have:
  epicsAtExit( rebootCbC,this);
then I have:
extern "C"{
static void rebootCbC( void* pvt){
  drvV792* pthis=(drvV792*)pvt;
  pthis->rebootCb();
void drvV792::rebootCb(){
  printf( "%s::rebootCb: Interrupts disabled and Soft reset\n",dname);
  fflush(stdout);
  epicsThreadSleep(1.0);
  _wtReg( ILEV,0);
  _wtReg( EVTR,0);
Writing 0 to the EVTR disables interrupts.  Also writing 0 to the ILEV register disables interrupts.
In fact, the same rebootCB code, seems to work fine in the non-asyn driver.
Is something subtle taking place because of vxWorks?
Can you offer suggestion on how to make it work?
Thanks in advance,
Zen
RE: epicsAtExit Mark Rivers
Prev: Re: XOFF Problem with tyGSOctal Bjorklund, Eric A
Next: Re: XOFF Problem with tyGSOctal Eric Norum
Prev: EPICS Collaboration Meeting Fall 2012, First Announcement 이은희
Next: RE: epicsAtExit Mark Rivers
