Subject: RE: epicsAtExit
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 28 Jun 2012 11:59:24 -0700
Thanks Andrew,
I have seen this message printed in the console while the IOC was booting.  At first I wondered about it then ignored and forgot it.  Is it desirable to have the vxWorks routine sysAtReboot(), that is, how important it is?
I could ask Ernest to include whatever needs to be included and rebuild vxWorks to have this routine available.  On the other hand, adding rebootHookAdd(epicsExitCallAtExits) to my st.cmd file fixes my immediate problem.
Thank you again,
Zen
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Thursday, June 28, 2012 11:29 AM
> To: [email protected]
> Cc: Szalata, Zenon M.; Mark Rivers; Williams Jr., Ernest L.
> Subject: Re: epicsAtExit
> Hi Zen,
> On 2012-06-28 Szalata, Zenon M. wrote:
> > I don't see the printf message in the console output.  I see no
> > evidence that rebootCB() is called.
> Does your vxWorks BSP provide the sysAtReboot() function that EPICS uses to
> register the reboot callbacks?  If not you'll see this message during booting,
> probably while loading the IOC's .munch file:
>     BSP routine sysAtReboot() not found, epicsExit() will not be
>     called by reboot.  For reduced functionality, call
> If you see that, follow its advice and see whether that solves the problem.
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
Re: epicsAtExit Andrew Johnson
epicsAtExit Szalata, Zenon M.
RE: epicsAtExit Mark Rivers
RE: epicsAtExit Szalata, Zenon M.
Prev: RE: epicsAtExit Szalata, Zenon M.
Next: Re: epicsAtExit Andrew Johnson
Prev: Re: epicsAtExit Andrew Johnson
