1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ethernet-based Gamma ion pump controller (mpc)
To: [email protected]
Date: Fri, 29 Jun 2012 09:15:22 +0200
If the checksum and setup are rights,
did you try to cross the serial to Moxa cable ?
Hope this helps
-Mauro
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Tel./Fax. +39.049.8068558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
On 6/29/2012 1:51 AM, Scott Baily wrote:
We're trying to control a Gamma ion multi-pump controller via ethernet from a soft ioc. The problem is that we can't get any response from the controller. We're using a stream device protocol file that previous worked for an RS232 gamma ion pump controller. Although I have also not been able to get any response by telnetting directly to the port and attempting to issue commands. This device uses a checksum, so the problem could be that the checksum is incorrect or some other problem such as the configuration of the MOXA serial to ethernet card that's internal to the device. It appears that I've configured the bit rate, parity, and stop bits to match the devices settings. What else should I be checking? perhaps the response is just not being transmitted over ethernet and I should configure data packing? or something else.
Re: ethernet-based Gamma ion pump controller (mpc) Pavel Masloff
Re: ethernet-based Gamma ion pump controller (mpc) Scott Baily
Prev: ethernet-based Gamma ion pump controller (mpc) Scott Baily
Next: Re: ethernet-based Gamma ion pump controller (mpc) Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
