Subject: |
ethernet-based Gamma ion pump controller (mpc) |
Scott Baily <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Thu, 28 Jun 2012 17:51:20 -0600 |
We're trying to control a Gamma ion multi-pump controller via ethernet
from a soft ioc. The problem is that we can't get any response from the
controller. We're using a stream device protocol file that previous
worked for an RS232 gamma ion pump controller. Although I have also not
been able to get any response by telnetting directly to the port and
attempting to issue commands.
This device uses a checksum, so the problem could be that the checksum
is incorrect or some other problem such as the configuration of the MOXA
serial to ethernet card that's internal to the device. It appears that
I've configured the bit rate, parity, and stop bits to match the devices
settings. What else should I be checking? perhaps the response is just
not being transmitted over ethernet and I should configure data packing?
or something else.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
- Re: ethernet-based Gamma ion pump controller (mpc) Jack
- Re: ethernet-based Gamma ion pump controller (mpc) Wesley Moore
RE: epicsAtExit Mark Rivers
<2012>
2025
2026
Re: caget limitation retreiving ENUM list Dirk Zimoch
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
