Subject: Re: caget limitation retreiving ENUM list
To: haquin <[email protected]>
Date: Fri, 29 Jun 2012 09:33:01 +0200
haquin wrote:
I have developped a record which has an ENUM field of 32 elements,
When I use "caget -d 31 PVname" to retreive the list of elements, I get only the 16 first elements.
Could the "caget -d xx" retreive more the 16 elements ?
Regards
Not without breaking the CA protocol.
You can try to change the MAX_ENUM_STATES macro in db_access.h and then re-compile all EPICS software. But you have to rebuild not only EPICS base but as well all clients. Client built without the change may not work with modified IOCs. Tell me if this works :-)
Dirk
caget limitation retreiving ENUM list haquin
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Pavel Masloff
Next: RE: LabVIEW EPICS connection ulrik.pedersen
Prev: Re: caget limitation retreiving ENUM list Andrew Johnson
Next: ethernet-based Gamma ion pump controller (mpc) Scott Baily
