Subject: RE: LabVIEW EPICS connection
To: <[email protected]>
Cc: [email protected]
Date: Fri, 29 Jun 2012 10:31:38 +0000
Hi Pavel,
I think you only need LabVIEW installed on that machine. The CALab installer makes it very easy to get started.
Cheers,
Ulrik
Sent: 28 June 2012 11:45
To: Pedersen, Ulrik (DLSLtd,RAL,DIA)
Cc: [email protected]; [email protected]
Subject: Re: LabVIEW EPICS connection
Hey Ulrik,
Do I have to have EPICS base installed on the machine with LabView? Or CA Lab has everything I need?
thanks,
Pavel
On Thu, Jun 28, 2012 at 2:26 PM, <[email protected]> wrote:
Hi Steve,
A while ago (a couple of years) I went through this process and tried out a few different EPICS-LabVIEW integration libraries. My first choice was also this NI supplied LabVIEW add-on. However, I had trouble getting this working well:
·         There is a significant lack of documentation even to help you get started, let alone to understand how it does Channel Access I/O.
·         I have had some trouble to get the add-on installed and working – and others have reported the same. See http://www.aps.anl.gov/epics/tech-talk/2010/msg00277.php
·         Once running I found that I couldn’t get array/waveform to work (possibly not supported at all)
·         Setting up shared variables is far too complicated for some of our novice LabVIEW users
I had a lot better experience with the CA Lab library http://www-csr.bessy.de/control/SoftDist/CA_Lab/ This worked straight out of the box for me and the documentation is excellent to get you started. Also it uses the native EPICS ca and Com libraries and makes the source code available so you can understand how it really works. I recommend going with that for any new project.
Cheers,
Ulrik
From: [email protected] [mailto:[email protected]] On Behalf Of Steve Kinder
Sent: 28 June 2012 10:03
To: tech-talk
Subject: LabVIEW EPICS connection
I am trying to connect an existing LabVIEW VI to EPICS via the freely available LabVIEW add-on EPICS Client I/O Server (http://joule.ni.com/nidu/cds/view/p/id/2533/lang/en). I am running LabVIEW 2011 and have a 3-14-11 soft IOC running on the same system with a few test PVs. My first aim is to make a connection between these PVs and elements of the LabVIEW VI (currently just a test VI). I wondered whether anyone had successfully used this LabVIEW add-on or the full version as in the DSC/RT add-ons and could offer me advice on how to make the connection.
I have the following in my test LabVIEW VI; Create EPICS VI, Deploy EPICS Client VI and List Records VI. I was hoping that the latter would display a list of records in my soft IOC if the connection had been established. I get no errors but it doesn’t seem to display any records.
Any advice would be appreciated, perhaps including whether I should be trying to use this LabVIEW add-on or one of the other options e.g. CA Lab or the Oak Ridge CA client.
Many Thanks
Steve
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
LabVIEW EPICS connection Steve Kinder
RE: LabVIEW EPICS connection ulrik.pedersen
Re: LabVIEW EPICS connection Pavel Masloff
Prev: Re: caget limitation retreiving ENUM list Dirk Zimoch
Next: RE: LabVIEW EPICS connection ulrik.pedersen
Prev: Re: LabVIEW EPICS connection Pavel Masloff
Next: Re: LabVIEW EPICS connection Steve Kinder
