Subject: caQtDM - getting not a valid Qt plugin error messages
To: "'[email protected]'" <[email protected]>
Date: Tue, 3 Jul 2012 20:32:28 +0000
Hi
   We are checking out caQTDM and have downloaded it from http://epics.web.psi.ch/software/caqtdm/
Unfortunately when we try to use it we get a “not a valid Qt plugin” error message for
·         libqtcontrols.so
·         libcaQtDM_Lib.so
I believe we have followed all the required steps and an ld/ldd command executed against the two libraries doesn’t show any errors or missing dependencies.
Has anyone else run into this or have some suggestions?
Thanks
Jimmy Johnson
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Scott Baily
Next: Re: mask for bitwise operation in CALC record haquin
Prev: Re: multi caput/get Williams Jr., Ernest L.
Next: FW: caQtDM Mezger Anton Christian
