1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mask for bitwise operation in CALC record
To: <[email protected]>, Andrew Johnson <[email protected]>
Date: Wed, 4 Jul 2012 10:34:36 +0200
Hi Andrew,
Will this modification be integrated in the next EPICS release ? when ?
regards.
Le 06/06/2012 18:23, Andrew Johnson a écrit :
Hi Dirk,
On 2012-06-06 Dirk Zimoch wrote:
I had assumed that the primary application for hex numbers would be bit
masks. Signed masks do not make much sense but 0x80000000 does make
sense. Maybe we should test for minus and then either call strtol() or
strtoul().
Agreed, I will do that (currently writing lots of tests...).
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
RE: mask for bitwise operation in CALC record michael.abbott
mask for bitwise operation in CALC record haquin
Re: mask for bitwise operation in CALC record Eric Norum
Re: mask for bitwise operation in CALC record Dirk Zimoch
Re: mask for bitwise operation in CALC record Andrew Johnson
Prev: caQtDM - getting not a valid Qt plugin error messages Jimmy Johnson
Next: FW: caQtDM Mezger Anton Christian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mask for bitwise operation in CALC record Andrew Johnson
Next: RE: mask for bitwise operation in CALC record michael.abbott
