Subject: Re: Problems with parallel make on seq-2-1-7
Date: Fri, 6 Jul 2012 14:33:04 +0200
On Friday, July 06, 2012, Mark Rivers wrote:
> I believe this is the same problem which we've experienced, but now
> fixed, in every synApps module that defines a new record.
> The .dbd files must be processed to generate the .h files.  When running
> without parallel make things worked fine with the existing src/Makefile
> rules.  However, when running parallel make it would occasionally fail
> because it tries to compile the record.c file before the record.h file
> exists.
> This is the change I made earlier this week in
> synApps/vme/vmeApp/src/Makefile:
> corvette:vme/vmeApp/src>svn diff -rPREV Makefile
> Index: Makefile
> --- Makefile    (revision 14860)
> +++ Makefile    (working copy)
> @@ -62,3 +62,6 @@
>  #  ADD RULES AFTER THIS LINE
> +# Parallel build sometimes fails.
> +# Make dependences on epidRecord.h explicit.
> +vmeRecord$(OBJ):          $(COMMON_DIR)/vmeRecord.h
> Once I added such lines to all Makefiles in synApps modules that build
> new record types then a parallel make of synApps has never failed.
> The problem we are seeing with seq looks the same.
Exactly. This time the problem is in RULES.Db:
$(COMMON_DIR)/%Record.h: $(COMMON_DIR)/%Record.dbd
	@$(RM) $(notdir $@)$(DEP)
	@$(DBDDEPENDS_CMD)
	echo "$< : ../Makefile" >> $(notdir $@)$(DEP)
	@$(RM) $(notdir $@)
	$(DBTORECORDTYPEH) $(DBDFLAGS) $< $(notdir $@)
	@$(MV) $(notdir $@) $@
(and five other similar rules in the same file). This would be correct:
$(COMMON_DIR)/%Record.h$(DEP): $(COMMON_DIR)/%Record.dbd
	@$(RM) $@
	$(MKMF) -m $@ $(DBDDEPENDS_FLAGS) $*Record$(OBJ) $<
	echo "$< : ../Makefile" >> $@
	@$(RM) $@
	$(DBTORECORDTYPEH) $(DBDFLAGS) $< $@
BTW, the new rule I proposed for .d generation needs an adapted definition
of HDEPENDSFLAGS in CONFIG_COMMON to work, i.e. instead of
HDEPENDSFLAGS = -m $*$(DEP) $(HDEPENDS_INCLUDES) $@ $<
we should have
HDEPENDSFLAGS = -m $@ $(HDEPENDS_INCLUDES) $*$(OBJ) $<
Cheers
Ben
> Mark
> From: Benjamin Franksen [[email protected]]
> Sent: Friday, July 06, 2012 5:59 AM
> To: Mark Rivers; [email protected]
> Hi Mark
> I add tech-talk to the list since this is a problem in the EPICS base
> rules.
> On Friday, July 06, 2012, you wrote:
> > With the old version it failed about 1 in 10 times at most.
> > With the new version there is a more serious problem.  It fails even
> > without a parallel make!
> > I did a parallel make on the clean and uninstall, but then a
> > non-parallel make on the build:
> > corvette:~/devel/seq>make -sj uninstall
> > mkdir ../../../include
> > mkdir ../../../lib/linux-x86
> > mkdir ../../../lib/vxWorks-68040
> > mkdir ../../../bin/vxWorks-68040
> > mkdir ../../../lib/vxWorks-ppc603_long
> > mkdir ../../../bin/vxWorks-ppc603_long
> > mkdir ../../../lib/vxWorks-ppc604_long
> > mkdir ../../../bin/vxWorks-ppc604_long
> > mkdir ../../../bin/linux-x86
> > mkdir ../../../dbd
> > ../snl.re:16:17: fatal error: snl.h: No such file or directory
> > compilation terminated.
> > make[3]: *** [lexer.o] Error 1
> > make[2]: *** [install.linux-x86] Error 2
> > make[1]: *** [snc.install] Error 2
> > make: *** [src.install] Error 2
> > If I do a parallel make on the build it actually works most if not all
> > of the time, but a non-parallel make fails.  This seems strange.
> I tried this on another comupter that runs a fedora linux today and I
> could reproduce this. The make version is 3.82 (on my system it is 3.81)
> and this is probably the same version you have.
> After the failed make (without -j) search for lexer.d; you won't find it.
> That means there is no dependency of lexer.o on snl.h and thus it does
> not get created before trying to compile lexer.c. If you add snl.h
> explicitly to the prerequisites of lexer.o
> lexer.o: snl.h
> Then the build works fine. However, this dependency should have been
> generated automatically, there should be a file lexer.d that lists all
> the dependencies of lexer.o on all the header files lexer.c includes.
> The parallel build works because the rules that generates snl.c and snl.h
> is executed in parallel and therefore in this case the snl.h
> (accidentally) exists. This is a excerpt of the relevanmt rules in the
> sequencer's Makefile (the fixed version, not the one in 2.1.7):
> snl.c: snl.lem snl.lt $(LEMON)
>         $(RM) snl.c snl.h
>         $(LEMON) o=. $< # this command creates snl.c and snl.h
> snl.h: snl.c
>         # empty recipy needed to work around make bug #35455
> vpath %.re ..
> lexer.c: snl.re
>         $(RE2C) -s -b -o $@ $<
> These rules are fine. What's wrong is teh rules in base that build the
> dependency files (.d). The following is from RULES_BUILD:
> %$(OBJ): %.c
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
>         $(COMPILE.c) $(call PATH_FILTER,$<) $(COMPILE_FILTER.c)
> %$(OBJ): %.cc
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
>         $(COMPILE.cpp) $(call PATH_FILTER,$<) $(COMPILE_FILTER.cpp)
> %$(OBJ): %.cpp
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
> This means .d files are not generated before the rules to compile a .c
> file fires. Instead they are generated together with the object files.
> This is bad, since it means that the header files must all exist or be
> explicitly added as dependencies.
> Instead, there should explicit rules that generate .d from .c:
> %$(DEP): %.c
>         @$(HDEPENDS_CMD)
> and similar for .cc and .cpp. When I add such a rule to the Makefile,
> everything build just fine on the fedora system with make 3.82. The
> $(HDEPENDS_CMD) can then be removed from the object generation rules.
> There remains the question what do about this problem? Should I add the
> extra dependency (lexer.o: snl.h) to the Makefile? Or should I add the
> missing rules for .d files?
> Cheers
> Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
Re: Problems with parallel make on seq-2-1-7 Benjamin Franksen
RE: Problems with parallel make on seq-2-1-7 Mark Rivers
Prev: RE: Problems with parallel make on seq-2-1-7 Mark Rivers
Next: sequencer release 2.1.8 Benjamin Franksen
Next: Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
