Subject: RE: stream device string/hex parsing
To: <[email protected]>
Date: Mon, 9 Jul 2012 17:19:25 +0000
Have you set
extrainput = Ignore;
In your protocol file?
Even so a better strategy would be to use redirection:
record (ai, "G2:ADC16-TEST_CH0")
    field (DESC, "ADC0")
    field (DTYP, "stream")
    field (INP, "@adc16.proto getADCs(G2:ADC16-TEST) ADC16_1")
    field (SCAN, "5 Second")
    field (FLNK, "G2:ADC16-TEST_CH1")
record (ai, "G2:ADC16-TEST_CH1")
    field (DESC, "ADC1")
    field (FLNK, "G2:ADC16-TEST_CH2")
getADCs {
    out ":0400000008..%<checksum>";
    in ":0410%4x%(\$1_CH1.VAL)4x%(\$1_CH2.VAL)4x%(\$1_CH3.VAL)4x%(\$1_CH4.VAL)4x%(\$1_CH5.VAL)4x%(\$1_CH6.VAL)4x%(\$1_CH7.VAL)%<checksum>";
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Gerrit Kühn
Sent: 09 July 2012 16:50
To: [email protected]
Subject: stream device string/hex parsing
Hi all,
I have set up stream device to talk to an ADC converter via rs232. The
records and protocols look like this:
record (stringin, "G2:ADC16-TEST")
    field (DESC, "answer string")
    field (INP,  "@adc16.proto getData ADC16_1")
    field (SCAN, "5 second")
    field (INP, "@adc16.proto getADC0 ADC16_1")
    field (SCAN, "I/O Intr")
[...] 8 adc channels
Terminator = CR LF;
getData {
    out ":0400000008..";
    in "%41c";
getADC0 {
    in "%*5c%4x";
I get the full answer string from the device into the first record. It looks like this:
pt@pt-steward ~ $ caget G2:ADC16-TEST
G2:ADC16-TEST                  :041000000000000000000000000000000000EC
The string needs to be parsed into numerals. The first 5 characters (command string) are not needed, neither the last two (checksum).
The remaining characters need to be processed in groups of 4 (16 bit per channel) and parsed from hex. This is what I intend to do with
in "%*5c%4x";
for the first channel. The next channel would skip 9 characters, the next 13 and so on.
However, this does not appear to work out. Everything works fine when I change the records to "stringin" type and parse for "%*5c%4c" instead. But parsing hex into ai never yields a single value.
Any ideas why this does not work, and how I can be made work?
cu
  Gerrit
Scanned by iCritical.
Re: stream device string/hex parsing Gerrit Kühn
Prev: EPICS channel access performance test tanushyam bhattacharjee
Next: New version of LabVIEW-EPICS-interface CA Lab Carsten Winkler
Prev: stream device string/hex parsing Gerrit Kühn
Next: Re: stream device string/hex parsing Gerrit Kühn
