Subject: Re: sequencer & button click
To: Martin Konrad <[email protected]>
Cc: [email protected]
Date: Fri, 20 Jul 2012 11:57:19 -0400 (EDT)
> From: "Martin Konrad" <[email protected]>
> what's the recommended way to switch from one sequencer state to
> another
> if a button is clicked on the OPI? What type of record do you use for
> this? What does the "when" statement look like?
I'm following on Ben's recommendation of using bi/bo records.  I've found to be very flexible for later additions of "user commands" and it's easy to read/debug later.  Using bi/bo makes your GUI easy too.  Ben's example showed mbbo.  Here's using a bo for operations.
short scanBtn;   assign scanBtn to "scan";   monitor scanBtn;
short zeroBtn;   assign zeroBtn to "zero";   monitor zeroBtn;
ss ... {
  state idle {
    when (scanBtn) {
    } state makeScan
    when (abortBtn) {
        /* bogus abort, just clear the button. */
        abortBtn = 0;
        pvPut(abortBtn);
    } state idle
  state makeScan {
    when (scanBtn) {
      /* do stuff, check for abortBtn. */
      /* then make sure to reset button! */
      scanBtn = 0;
      pvPut(scanBtn);
    } state idle
Hope this might help.
Wesley
Re: sequencer & button click Martin Konrad
Prev: Re: sequencer & button click Benjamin Franksen
Next: Re: sequencer & button click Martin Konrad
