1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynPortDriver
To: [email protected]
Date: Wed, 25 Jul 2012 10:33:09 -0500
Hi Mark,
On 2012-07-24 Mark Rivers wrote:
> I just realized that the problem is that there no mutex preventing the
>  callback from overwriting the waveform data at any time when the waveform
>  record is processing, which is bad.  Note that is problem is confined to
>  I/O Intr scanned waveform records, it does not happen on other records
>  that use a ring buffer.
> I think the solution is to call dbScanLock during the time the array data
>  is being modified in the callback.
I haven't looked at your code changes, but I suspect that this is causing the
problem.  As a general point no code should ever modify any record field
values unless dbScanLock() has been taken first.  On an SMP machine even
reading fields without taking dbScanLock() might give bogus values for some
field types if another processor happens to be writing to the field at the
same time that your code is reading it.
Some record-type authors have also been known to use public fields for
temporary storage of a partially-calculated result while their process()
routine is running, which would become visible if you don't use dbScanLock();
I don't think this applies to any of the Base record types any more, but I
haven't done an audit of them for this.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
asynPortDriver Szalata, Zenon M.
RE: asynPortDriver Szalata, Zenon M.
RE: asynPortDriver Mark Rivers
Prev: Re: asynPortDriver Hinko Kocevar
Next: RE: asynPortDriver Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
